$149.99 USD
$149.99 USD
$149.99 USD
Model:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 160 reviews
87%
(139)
11%
(17)
3%
Matti
Fosi za3
Best sounding amp
Wesley Garcia
I wish I had the power supply for the ZA3
s
Fred Kettler
Live studio setup - so far so good...!!
While I have only used the amp a handful of times, it has proved to be an excellent value thus far. My application is a bit unique as follows - a Yamaha mixing board's "balanced" output directly into the ZA3's balanced inputs, feeding a pair of Wharfedale Diamond 9 / 2-way 87db bookshelf speakers that I already owned. I play keyboards, synthesizers, electronic drums, and vocals and the amplifier is both dead quiet and sounds fantastic with minimal EQ from the mixing board. I tried this instead of using a pair of Active (self powered) studio monitors and I am very impressed. I imagine connecting a DAC and streaming high quality recordings would sound quite wonderful as well.
Jonathan Bigras
Powerful at a great cost.
My Micca RB 42 have never sounded better!
Ted Peacock
Well Done Fosi Audio!
I originally was using this amp myself but I soon saw my son enjoying the sound coming from it. I did give it to him and I believe started him on his way to enjoying music through a component system apposed to portable BT speakers which are severely lacking to say the least. I have a set of mono amps coming as soon a fosi ships them. The sound from this amp and having a sub out is awesome. Be it music or movies the ZA3 is a solid choice.
