$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 241 reviews
88%
(211)
9%
(22)
Larry Mapes
Where's my stuff?
I haven't received my order yet. Whats up?
Martijn
Wonderful little power amp
I bought this amp after reading / watching all the positive reviews. To complete my new desk setup, I was looking for a small but powerful and "clean" amp. The ZA3 delivered! Apart from great sound and for me more then enough lower (no need for the dual mono block setup yet), the amp looks very cool to. As I'm from the Netherlands, I love the orange power / volume button obviously. If you are looking for an affordable and powerful but small amp, look no further. You can't go wrong with this one.
Francois Smith
ZA3 for XLR sound quality...
This is now my second ZA3...
It is running with the ZD3s input and I love that warm precise sound that it supplies to my old Infinity Beta 50 speakers.
Can enjoy it for hours.
Markus Winterleitner
Top notch!
Top notch!
Roy Ledwell
Very Impressive!
I bought a bundle so I could use these in mono mode. I have not switched them from stereo mode yet. I am impressed with the output. I have a WiiM Ultra ran to both amps which are pushing two sets of speakers. One set is a pair of Definitive Technologies BP-30’s. They can handle 500 watts per channel. Even in stereo mode with eight ohms these things sound incredible. Love these little amps!!!
