$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 239 reviews
88%
(210)
9%
(22)
Francois Smith
ZA3 for XLR sound quality...
This is now my second ZA3...
It is running with the ZD3s input and I love that warm precise sound that it supplies to my old Infinity Beta 50 speakers.
Can enjoy it for hours.
Markus Winterleitner
Top notch!
Top notch!
Roy Ledwell
Very Impressive!
I bought a bundle so I could use these in mono mode. I have not switched them from stereo mode yet. I am impressed with the output. I have a WiiM Ultra ran to both amps which are pushing two sets of speakers. One set is a pair of Definitive Technologies BP-30’s. They can handle 500 watts per channel. Even in stereo mode with eight ohms these things sound incredible. Love these little amps!!!
Aljosa Krzelj
Happy !
Great little amp
Al Rourke
No power supply
Unfortunately I have not been able to try the ZA3 as it did not come with the power supply.
I did send a email regarding this problem but but have not received a response as of yet. Very frustrating!!
