$179.99
+ Free shipping
XLR Output / Trigger In/Out
Perfect Match to ZA3 Amp
Quantity
Free shipping
Money-Back Guarantee
Customer support
$149.99
$109.99
$475.99
cheapaudioman
View
iiWi Reviews
View
VirtualHiFi
Is The FOSI ZD3 Worth It?
View
Toids DIY Audio
View
SNR≥126dB; THD+N<0.00008%
High-End Components
Loseless Wireless Streaming
1.5-Inch OLED Display
Fully Balanced Output Design
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
Based on 130 reviews
83%
(108)
10%
(13)
3%
3%
Petru Grati
Terrible shipping
Fosi sent my recently ordered ZD3 and V3 that I ordered separately in a single shipment to save some bucks. Because of that I had to pay 2000 MDL to the border customs, which is about 110$. If they sent them separately as I ordered I would pass under the taxable amount. Deeply disappointed.
ZD3 and ZA3 Kombi
Wow, das ist ein Pärchen das es in sich hat, Leistung satt und unfassbar einfache Handhabung! Super wäre wenn Fosi eine schickere Fernbedienung (Größer) anbietet und im Shop ein Kurzes XLR Kabel! Das System treibt bei mir 2 Wharefadale Jade5 an und einen Hornlautsprecher aus den 70ern von Living Audio! OpAmps zum tauschen und testen sind bestellt! Bin Mega zufrieden und habe mir noch ein Pärchen bestellt!!!
Michael Catalano
Sounds great
Amazing that these little amps produce this much power with great sound. It gets plenty loud for me with my bedroom tower speakers. Might try amp rolling at some point because I like to play but sounds great out the box. I wanted the orange knob but mine came with black so had to order an orange knob.
Carlos Arana
ZD3
Cambie mi eversolo z8 que es mucho mas caro por el z3 de fosi , estoy contento musicalmente no he perdido nada , puedo desactivar el pre amplificador y usar la entrada y salida trigger que el eversolo no tiene. He vendido el eversolo y recuperado dinero con el cambio sin nada de que arrepentirme .
James R
I smiled
My fist listen was from my PC to a 50W type D/tube receiver and inexpensive desktop speakers.
That’s when I discovered what was missing in that system! Very Enjoyable experience.
