$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 227 reviews
88%
(199)
10%
(22)
James R
Clean and potentially Loud
This amp pairs well with the ZD3 and sounds wonderful on my small system.
Simon Rocheville
Not received yet after 20 days
I paid for fast shipping (25$) to get my order in 3-7 days like it was indicated on the website but 20days later still didn’t get my order ...
Juan Manuel Muñoz Gonzalez-albo
Excelente servicio, excelentes productos
Desde el primer momento han sido muy amables conmigo, me han dado diferentes opciones, se han adaptado a lo que necesitaba y me han aconsejado en todo lo que necesitaba.
Les doy 5 estrellas; volveré….
Bill
Amazing Little Amplifier
I bought the ZA3 mainly given its functionality and small footprint. The ZA3 was exactly what I needed for the sound system in my home office, analog inputs, 2 channel stereo and subwoofer analog output, and I purchased it with the basic 32V; 5A PSU. Currently it’s paired up with 25 year old NHT Super One speakers (86 dB efficiency), and is fed by the stereo single ended outputs from the Visio TV, which in turn is fed by an Apple TV unit. The only thing I needed help with was turning the unit on, which I referred the manual. I ran a bit of a stress test for an hr, both channels playing rock at loudness levels far above normal listened levels, to validate the thermal design. In a closed cabinet, the bottom of the case was maybe 5 degrees above ambient, and the top less so. The Fosi Audio engineers did a great job at a fanless design, and IMHO did a wonderful job on the implementation. In about a year, as I expand the system, I’ll be looking for a preamp with XLR outputs. Summary: Excellent value, great performance, and clever product design - the Fosi ZA3 is a winner.
David Dunlap
Best sounding and looking mini amp for the money!
Amazing sound quality, and a lot of power in a small footprint! Be sure to get the 48 V power supply If you want to squeeze every little bit of performance out of this Amazing Little Amp. I only wish they had something like this when I was growing up in the 80s and 90s. We would look through JC Whitney catalogs and order these little Pyle amplifiers because that’s all we could afford. And they had like 10% harmonic distortion and sounded absolutely terrible compared to the ZA3. I would love to see some active cooling when they come out with their new models because the ZA3 and the mono blocks do run warm. Especially after long listening sessions Cranked up to 11. I would not even mind if the cases were slightly bigger to accommodate small cooling fans. I also believe this would add to the longevity of the components of the Amplifier and possibly produce more power.. And you could still keep the Z product line but maybe come out with A slightly more expensive R series ? “ reference” lol. . And make sure that all of the case sizes are the same so you could make a real nice looking stack. Also leave more room for op amps so you can easily fit the massive sparkos op amps in the cases. I bet a lot of people would be totally all over that!. Keep up the good work. I’m so happy that everybody can afford High quality audio equipment without breaking the bank!
