$179.99
+ Free shipping
XLR Output / Trigger In/Out
Perfect Match to ZA3 Amp
Bundle Offer - Save 15%!
Quantity
Free shipping
Money-Back Guarantee
Customer support
$149.99
$109.99
$475.99
cheapaudioman
View
iiWi Reviews
View
VirtualHiFi
Is The FOSI ZD3 Worth It?
View
Toids DIY Audio
View
SNR≥126dB; THD+N<0.00008%
High-End Components
Loseless Wireless Streaming
1.5-Inch OLED Display
Fully Balanced Output Design
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
Based on 125 reviews
83%
(104)
10%
(13)
3%
Peter Hadfield
Hdmi
Bought to connect LG TV to HI FI by HDMI.
Great. One clicker. TV clicker clicker works volume. TV clicker turns tv and zd3 on and off the a single button.
My none tech wife operates single TV clicker and does not twig sound s through HI FI.
Zd3 connects to two FOSI monoblocks very good
Sébastien Bouchard
Little box, but amazing performance
This little machine, the ZD3, is simply incredible for its very affordable price. The device delivers a highly defined sound without sacrificing the warmth that makes music listening so enjoyable. Add to that a fairly open sound that fills the room well, and you get a device that produces a complex and enjoyable soundstage. Its highs, mids, and bass are simply well-balanced. A slight lack of refinement in certain highs and mids can be mitigated by using a coaxial or USB connection, as the optical connection tended to accentuate this negative aspect. The ZD3 remains a Hi-Fi audio device worth considering, even with high-end equipment. Its price may not reflect the essence of high-end Hi-Fi products, but its sound quality and performance are in a league of their own.
John Szuhay
Great DAC
The ZD3 hits way above its weight class! Coupled with the V3 monos the performance is hi end.
Daniel OBrien
Do not have it yet.
I have not received this yet.
DAVID CANON
Great DAC. A must for the ZA3
Awesome DAC! My setup is now fully balanced using XLR cables. The sound is fantastic—no noise, and I can definitely hear the difference. I love the design; it looks beautiful.
