Fosi Audio BT20A PRO 300W x2 TPA3255 2 Channel Bluetooth 5.0 Power Amplifier
$79.99
+ Free shipping
Bass & Treble Control with Midpoint Positioning
Bluetooth Pairing Cleared
MODEL
Quantity
Free shipping
Money-Back Guarantee
Customer support
$475.99
Fosi Audio BT20A Bluetooth 5.0 Amplifier 2 Channel Stereo Amp Receiver Class D Amplifier for Home Audio System
$79.99
Fosi Audio Banana Plugs for Speaker Wire, 2 Pairs/4 PCS Gold Plated Speaker Plugs
$9.99
The upgraded version of Fosi Audio BT20A
Input: Bluetooth + RCA; Output: Passive Speakers + Pre-out
Amp chip: TPA3255; MAX Output Power: 300Wx2@4Ω
THD: ≤ 0.005%; SNR: ≥108dB; Frequency Response Range: 20Hz-20kHz(±1.2dB)
Bluetooth 5.0 Connectivity
Allowing you to connect your devices such as mobile phones and tablets from a greater distance, support to SBC/AAC.
Unique Design for Sound Control
Experience the authentic sound without any added effects by adjusting them to their middle points.
Full-range Pre-Out Output
Easily connect to a powered subwoofer, speaker, or another amplifier for versatile audio options.
Texas Instrument TPA3255 Chip
Has a unique smart algorithm that optimizes the output stage for max efficiency and min distortion.
Achieve a Distinct and Exceptional Sound Quality
The two plug-in NE5532 Op-Amps can be replaced by LME49720HA/MUSES02/OPA2134PA Op-Amps, etc.
High Precision and Stability Inductance Values
Low DC resistance and excellent frequency characteristics which improve performance
Front Side
Back Side
Power Variability
Amplifier Comparison Table
BT20A PRO
HT4S
V3
Bluetooth 2.0 CH Amp
Bluetooth 4.1 CH Amp
2.0 CH Amp
300W x 2
30w*4+60W*1
300W x 2
Bluetooth + RCA
BT + 3.5mm AUX + OPT
Passive SPK +Pre-out
Pre-Out+SPK Out
Treble&Bass Control
THD
≤ 0.03%
≥88dB
  • TI TPA3255 Chip Amplifier with 300 Watts x 2 Power Output: Advanced feedback design and high-speed gate driver error correction for efficient and high-quality audio performance, with low idle losses of <2.5W.
  • Upgraded High-Efficiency: A significant upgrade from the BT20A amplifier with replaceable Op-Amps for customized. You can replace the two plug-in NE5532 Op-Amps with MUSES02/OPA2604AP/SS3602 Amps to achieve a unique sound quality. With SNR≥108dB and THD≤0.005%.
  • Enhanced Bluetooth 5.0 Connectivity: The Bluetooth pair can be cleared by pressing and holding the volume control for five seconds. In addition, it has a memory Function for Easy Pairing and Alert Tone.
  • Customizable Sound with a Wide Range of Bass and Treble Controls: The BT20A Pro home audio amplifier offers a unique design for sound control. Enjoy original sound without effects by setting treble and bass effects to the middle point.
  • What you Get: BT20A Pro Power Amplifier x1, Bluetooth Antenna x1, 32V 5A Power Adapter x1, AC Cord x1, User Manual x1, our worry-free 24-month warranty, and friendly customer service.
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
Based on 136 reviews
82%
(112)
13%
(17)
3%
John624
Good small, low cost amp
Performs as expected and very good for the money, but a few improvements are needed to make this a 5 star product. First, it runs too hot with the 48V supply. When idling, it's burning about 20W. I turn it off when not using to save power, but this should be automatic. Best solution - decrease idling losses with higher supply voltages. Next best solution, shutdown power stage when signal falls below threshold to avoid power loss when not in use.
Also, once a Bluetooth device is registered, it should be able to auto-connect. Having to manually reregister a Bluetooth source is a pain and seems unnecessary today. I have 10 year old smart speakers that don't require this.
To be clear, I'm nitpicking and I wouldn't hesitate to buy another one if needed. This is a very good amp, but it could be great.
John Cossa
II would love to give you a review but I am looking for the proper bookshelf speakers to use for classical music. Can you help?
B Campbell
Great bluetooth amplifier (with limitations)
The BT20A is a great 2 channel amp. Its very small. deceivingly powerful despite its size and the bluetooth receiver has plenty of range.
It is powerful enough to power 4, 8-ohm speakers, in parallel, with out distortion.
That being said I bought the 48v, 5 amp power supply. From what I understand you will only receive the full advertised output if you purchase the 48v 10A power supply which is more expensive than the BT 20A Pro amplifier. I didn't learn that fact until after i had placed my order.
The sound is great! I would like to power 6 speakers with it, I'm not sure it would handle the load.
I have used the optical fiber input from one TV, that worked well, and I have connected to it Via bluetooth from a different TV which also works very well.
What I don't like is, you can't connect a new bluetooth device without clearing out the first device. That's annoying because in order to connect the original device again you need to clear the amp from your device settings and re-pair it.
One last point you have to leave it in an accessible place so you can push the pairing button and adjust the volume.
A remote control would be a great addition.
J.B
Fosi BT20A Pro
Fantastic little amp ! I purchased it with the 48V power supply, definitely try get it with that instead of the 32V supply. Great connectivity and good power! I use it with Elac Debut 6 and this little amp does a great job driving them. Great too that it has Bluetooth connectivity! Highly recommended.
Paul Ljungqvist
Very impressive
It is a small amplifier, but with great sound. It easily drives my Dali Blue 5005.
Bought it with 48V option and GaN
