$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Dear V3 mono owners,We are kindly to announce that the output polarity of V3 MONO has been revised since August 2.
For V3 MONO units purchased on or after August 2nd, 2024: The output polarity of V3 MONO has been revised. You can connect your speaker terminals normally without reversing the polarity.
For V3 MONO units purchased before August 2nd, 2024: Using two V3 Monos together won't cause any phase issues. However, if you integrate one V3 Mono with other equipment, please note that the phase might be inverted. To achieve optimal sound quality, please connect the speaker terminals reversely when connecting to your V3 MONO amplifier.
If you purchase the V3 Mono from the Fosi Audio website after August 2nd, 2024, it will be the updated version. For purchases from platforms like Amazon, eBay, or AliExpress, please contact our customer service to confirm which version you are receiving.We apologize for any inconvenience caused by this and appreciate your patience as we worked diligently to rectify the problem.
If you have any questions or require further assistance, please contact our customer support team: support@fosiaudio.com.Kind regardsFosi Audio Team
Based on 68 reviews
74%
(50)
12%
(8)
7%
(5)
6%
Chris Osler
Have not received
H Chan
One of the V3 mono block amplifier does not have sound
I bought 2 V3 mono block amplifiers in Sep 2024. After listening for few times , one of the amp did not have any sound.
I sent a ticket to support and was promised to get a replacement board. However, I got an old/refurbished replacement board which was manufactured in 2023.
I am very disappointed receiving an old board but support said the board was fully tested.
This is not acceptable to replace the faulty board with an old one. After all, the product should have 24 months warranty and clearly the board is a faulty one.
I requested to provide a new board and am still waiting for reply from support.
It is a very disappointing and bad experience !
JAYAN KALARIKAL
Clarity and power
Its powerful, clear and compliments well with my Fosi X2.
Dorian
Excelent
Listen, first of all i have an class AB Emotiva Basx A300 amplifier that is 200 W / Channel .
So then the Fosi arrived, i was sceptical of course . My soruce is PC with usb cable to Topping D50 III - XLR(TRS) - 2 x Fosi V3 Mono - Canton Karat Floorstanders 3 way Speakers .
I want to say i lost nothing in quality , more i hear new sound now , the treble is just right, and the bass has that uomph to it, is hard and thick . I cant believe that they are better than emotiva amp - really powerful . The only thing that i notice is the volume is a little little under the emotiva , but the quality is over and over better than Emotiva .
They get a little hot to the touch - i keep them separate side by side , but i am in the process of making some stand for them with some usb fans .
So class AB fans , just give them a try , i think you will not regret it .
Fosi , best wishes and keep up the good work ! You are awesome , quality products and accessible prices !
Zoran Jankovic
V3 Mono
I bought 2 V3s in pre-sale. I paired them with a ZD3 DAC via XLR Todn cables and the sound is excellent. I also own a High End Class D Amplifier Buchardt I150 2x 300W which costs 2500 Euros in direct sales. If it were sold through a dealer it would be significantly more expensive, probably between 4000 and 5000 Euros. I can say that the Fosi V3 Mono works almost the same as the Buchardt which is a 15 times more expensive amplifier. The difference is insignificant.
If you buy expensive branded amplifiers just for the tradition and name, you are wasting a lot of money.
